1.2 TSI CBZB - Timing Chain / Crank Sensor / Cam Sensor
Hi All
Glad to be part of this community :)
I need some guidance with my 1.2 TSI CBZB engine.
Recently my EML has come on - I have checked the codes and this was the code that was scanned - P001600 - Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor A.
After seeing this code I changed the Cam and crank sensor, I then had the code cleared but the same issue persisted 😞
I was reading up about this and it may have been an issue with a stretched chain.
I have had the chain replaced and yet I am still encountering the same problem.
Does anyone have any idea or advice on what else could be causing the issue?
Make - VW
Model - Golf
Engine - 1.2 TSI (CBZB)
