All headlights on right side not working
Hello, any helpful suggestions would be gratefully received.
All the headlights on the right side don't work (main, dipped and sidelights). All on the left work fine.
Bulbs ok and fuses ok. The connection to the headlight.looks ok.
It doesn't seem like  it could be the relay..
What could it be?
Problem solved, all the bulbs failed at the same time. Don't know how to delete this post.
You can't delete an entire thread, not even your own. BTW, blowing all three bulbs on one side of a car and none on the other is unusual. If you hadn't noticed, I'd have suggested checking the headlight earth.
