Fogs/Sidelights as CH/LH Help
Hi all,
I'm hoping someone could help me with trying to get my fogs-only working as CH/LH.
I've followed the guide and they're working but the sidelights still seem to come on as well and I can't figure out why.
Would someone be able to look at my adaption map and assist at all please?
adpmap-09-5Q0-937-086-AK_TMBMJ7NE5G0063276-20220412-1409.CSV
At a guess, I'd be taking a look at:
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26
All are set to "Coming Home oder Leaving Home aktiv" and probably need to be 'not active'.
Not sure if it just the first pair, second pair or both sets that need changing.
Thanks - I wondered that as well but then thought maybe these are the rear lights?
maybe it’s trial and error on these??
Also is it weird that the 2nd two, one is B and one is E?
Seems I missed one.
Anyway, there are three pairs and one single lamp output that are obviously set as CH/LH at the moment.
Leuchte20BR LA71 and Leuchte21BR RC8 which is probably the rear tail/brake lamps:
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,not active ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Coming Home oder Leaving Home aktiv ,16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active ,16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active ,16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,not active ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Coming Home oder Leaving Home aktiv ,16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active ,16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active ,16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active ,16
Leuchte23SL HLC10 and Leuchte24SL HRA65 which are probably the sidelights/DRL (same bulb?):
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Coming Home oder Leaving Home aktiv ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Daytime running lamps ,16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active ,16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active ,16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active ,16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active ,16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Coming Home oder Leaving Home aktiv ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Daytime running lamps ,16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active ,16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active ,16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active ,16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active ,16
Leuchte25KZL HA59 which is probably the rear license plate lights:
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,Coming Home oder Leaving Home aktiv ,16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active ,16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active ,16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active ,16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active ,16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active ,16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active ,16
Leuchte26NSL LA72 and Leuchte27NSL RC6 which are probably rear tail/fogs based on translating "Nebelschlusslicht wenn kein Anhaenger gesteckt":
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active ,16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,Coming Home oder Leaving Home aktiv ,16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active ,16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active ,16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,Parking light right ,16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,Coming Home oder Leaving Home aktiv ,16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active ,16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active ,16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active ,16
Given the choice, I'd start with:
This is so helpful so thank you. I’ll try this to night and see if it works!!
Interestingly it still said drl for the sidelights but I disabled those as I’m running the dogs as drls so that’s also weird
Sadly this didn’t work and I’m totally stumped. I’ve remembered that the sidelight bulbs/drl are:
12)-Leuchte4TFL
(12)-Leuchte5 TFL
this is from when I disabled them for drl but even these don’t have any reference to ch/lh so who knows.
maybe the sidelights are coming on because of another setting when I disable the alarm/turn the ignition off
