New RTS Clutch and SMF Not Disengaging
As the title says, I have installed an RTS Clutch and Flywheel kit ((RTS-5389SMF) - HD) to my Skoda Octavia 2.0 VRS TFSI, BWA engine, KNU gearbox. The clutch pedal does not disengage the clutch following installation, bearing in mind this wasn't an issue before. I inspected the original clutch release bearing (new kit doesn't come with one) and found it to rotate freely and look in generally good condition, so I left it in.
I've tried bleeding the clutch and have purchased a Gunson Eezibleed, which was great and will be using again, and followed the workshop instructions for bleeding the clutch system (100ml out the bleed valve and pump, 50ml out the bleed valve), even went as far as doing this multiple times. Pedal travels to the floor with constant resistance all the way down and then returns, but it feels light. Making me think the release bearing isn't contacting the clutch fingers at all. Gearbox is seated all the way to the engine and all looks good and secure there too. Kit instructions don't recommend a replacement release bearing so far as I can tell and I'm at a loss as to what to try next. Any help appreciated.
