WD-40 Error
Like an idiot, I sprayed WD-40 Specialist Grease on the tracks of my car's windows, instead of the Silicone spray.
So will the rubber in the tracks be damaged?
[Google says grease degrades rubber.]
Thanks.
Try mixing some fairy liquid with hot water & use a tooth brush to scrub the window channels.
Tip - Use the wife’s toothbrush……..you don’t want to mess yours up!  😎
@OccySportThanks. Sounds like a plan. I pinged the WD-40 people & they said the stuff probably won't do much harm but am going to try & remove it all & put silicone spray in its place anyway. Cheers.
