Anyone whose fitted MFSW to a pre-fl, help please
1K0 953 549 AG is the steering controller I've fitted yet whatever I play with in VCDS, they never work.
I had them working with another controller, but the steering sensor wasn't part of the module so the cruise didn't work.
From all I can see, this module should let me use the MFSW yet clearly it doesn't
I have the required wiring.
Only other electronic mod I've done is fit a later gateway module to allow use of the RCD330.
Could someone with a pre-fl share the module they have? Kinda tired of having the buttons and not using them!
  • 7 months later...
Bump - could this be to do with the Lin version? Controller in use is 1.3, desired looks to be 2.0 for the RCD330?
