Rear washer - 2018 FL Octavia Estate - how to clean / replace.
Hi,
I've searched, but most of the posts seem to relate to the Saloon / Hatch which has the washer jet in the wiper arm.
Symptom:  Motor engages, a decent amount of water comes out but it is coming out like a tap rather than misting or "spraying".  The flow is limited to the top of the wiper blade area.  As such, I have to have it on longer to wash the window (to try and get they water nearer to the bottom of the window as the wiper blade wipes it away), and a good amount of it is deposited on the boot sill when the wiper goes past where it can pool.
On my estate, the washer nozzle is contained in the rear reflector on the top of the boot (above the window).  Does anyone know if I can:
a) take it off easily to have a look and blow some air through it or something
b) if not, and I have to get a replacement, can I replace just the washer nozzle or do I need to replace the entire reflector (and what would the part number be)?
Any help or pointers gratefully received.
Thanks,
Stephen.
I think they are all like that - mine's always been pathetic.
