Infotainment screen suddenly stops working and it's not the fuse!
Hello all ... I do hope someone can help! As the subject line ..... this happened 2 days ago since when I've tried the "reset" procedure and also inspected/replaced the relevant fuse.....  the screen is still blank and won't connect with my telephone (the most impopsrtant thing)....... any ideas? (On a budget, sadly!) TIA
Do you have VCDS or any other diagnostics tool to connect and check via CAN?
Sadly no I don't I'm afraid .....
Then I suggest you find someone on Briskoda who is close to you and has such a tool (VCDS, Vag Can Pro, OBD Eleven, ODIS) and can connect to see if there is any communication possible with the unit. meanwhile you can let me know VIN on PM so I can check your car configuration and let you know what the options are.
