Orange engine management light
I own a Skoda vrs 1.4 and the orange engine management light come on the other day I looked it up and it says emissions but ever since it doesn’t seem to be pulling properly anyone ever experienced this? Thanks
Hi mate it could be a multitude of things with the 1.4 tsi vrs but I would start looking at when the spark plugs where replaced and pulling them and checking there condition also worth checking the coil packs if not you could have more serious Problems like piston/valves on the way out , be worth scanning for fault codes and posting them here so we can assist further
Hi thanks for the reply put a obd reader on it and it’s coming back with a fault for the magnetic clutch for the supercharger and after looking it up it sounds likely with having no low end power, witch is typical has I’ve just had it back from getting the water pump done.
Hi check that the fuses haven’t blown for the water pump under the dash or they haven’t plugged the connector in correctly
