Dual climate control problem
Not even done 100 miles in my new RS and the dual climate has decided to stop working!
If you turn the fans up manually nothing happens - the lights go up but not fans!
The same happens when you set to auto as well!
Any ideas? or is it back to the dealer for me?
:confused:
Back to the dealer. Sounds like the fan is knackered or has a bad connection.
Loose connection!
Cheers for the response
Fuse?
Loose connection!
Any idea where abouts....for future reference ?
Look at your handbook it is all in there you have two fuse panels, one in the engine compartment and the other on the RHD side of your dash panel, although very often you only find the fuse you require is only located in one place.
Hiya, Sorry havent got much of a clue, other than its round the passenger side - under the bonnet at the back........ sorry he only quickly explained.
No probs :thumbup:
