Battery size - VRS TDi 2021
Checked both Tayna and ECP and they both give different options for the battery size from 096 to 100 to 027.
What size do you use?
My current one ‘looks small’ for the size of the battery tray so can’t rely on that.
Cheers,
Simon
Cheers,
Simon
Take a picture of the code on the battery, also dimensions are easy to obtain.
Sounds like 027, a dinky battery size.
096 are hearty size of about 278mm in length.
Thanks - I’ve gone for a 096 👍
AGM?
If yes, is this same as you are swapping from?
And do you have the correct fibreglass blanket it should sit in?
I went with a standard type - Bosch S4.
