Fabia Mk3 broken screen.
Hi all,
I have browsed forum but cannot see anything similar to my issue described (see picture).
I removed the unit w/ release keys and didn't notice any lose connections, etc. I assume it's a broken screen and needs a replacement. If so is it best to go like for like or are there any branded replacements you guys would recommend.
Thanks in advance!
brknscrn
I also bought second hand and am unsure whether the screen is water damaged or whether that is glue that can be seen!
Looks like water... What is your location?
UK, I might add the screen showed water damage for 2 years before it went like you see with the line down it. That happened when on the motorway.
Best tag a user if they are not following the thread.
@pab567 [write @ followed by name]
He should now pickup your answer.
EDIT: I see a double-post, so have asked admin's to hoover up previous one you made.
Edited by varooom
EDIT: I did see you quoted him, so that should automatically ping him!
Apologies for making small mistake 🤝
Thanks bud. My mistake, thanks for the catch!
Do you need anything from my side? I have a screen but I'm located in Poland so I guess you may find one locally.
  • 2 months later...
Sorry for the late reply @pab567 a combination of a new baby and a throwaway email!
Here is an example I have found but seller says it is coded. I assume I can just buy a code of this is the case?
I think I did read you comment somewhere that it has software protection instead.
Any ideas?
Thanks again!
Displays are NOT protected, just the glove box units.
Thank you, I will buy if it is plug and play!
@pab567all seems to be working with replacement. PM if I can buy you a drink.
