Power steering
Hey so my power steering has decide to break , I have replaced the pump that I got off of a vw fox (same pump) I have checked voltage , belts and fuses I have checked fluid levels and still no joy
I tried reading for fault codes with a Ross tech vcdm but it just says that there is no response from the power steering module has anyone else had this or know how to fix this thanks
  • Sponsor
Was cabin fuse no.7 one of the ones you've checked??
Yeah checked this fuse was perfect
  • Sponsor
Do you see 12V at the pin that fuse supplies at the PAS pump, when ignition is on? Black/yellow wire, pin 4 of the 4-way connector.
Yeah it’s running .6 amps
