sqeeky Suspension
My suspension Sqeeks ?
my clutch sqeaks, perhaps its that? I asked and seems a common problem. Does it happen when you take up drive, and when changing gear?
Does it happen when you go over speed humps and does it seem as if the noise is coming from the rear?
good point DGW, I forgot the estates have a bit of a squeek and rattle if not carrying any load. I just blank that out now as i know what it is.
try spraying some wd40 on the front suspension arm rubber bushes at their mounting points. If this temporarily solves the problem the bushes are bad and the arms will need to be replaced (much MUCH easier then changing the bushes. I bought a bush kit from IML and i could not get them over the old arm even with my hydraulic press.) same for the back, but if the back stops squaking then you will need to change the shock cartridges
