Substantial increase in fuel consumption
So my beloved 2.0 TSI SE L suddenly has a huge thirst.
The daily commute has gone from late 40's early 50's MPG, to mid to late 20's MPG.
No fault codes.
Tested at garage and EGR, O2 sensor, Air Con, Secondary Air con, Evap Emissions, Catalyst heating and operation all within normal parameters.
Tyre pressures all good.
Brakes not binding.
I haven't changed my route to work or changed my driving style.
Fuel used is still Tesco Momentum from the same garage.
I'm starting to think laterally, like could it be something the engine drives, like the water pump or alternator causing drag?
Could the MPG-ometer be faulty? (I need to test this next fill-up.)
Slightly baffled, but enjoying the challenge of a mystery fault.
I'd like to find the problem now, before anything catastrophic happens.
Anyone got any suggestions as to vectors of attack on the problem?
Don't trust gauges, use the fill at the same pump every time to keep the car as level as possible. Record the milage before filling and fill with the same amount or until the pump shuts off.
I had a diesel Focus that showed fuel consumption and it showed an average. Same work run different traffic conditions higher consumption!
When were the spark plugs replaced, or the air filter, or even inspected? What age of car having done how many miles?
That's one heck of an increase!
Thinking out loud - not had any recent work done on the car? MoT? - my cars always dip once back from MoT, and either slowly recover, or come back if I remember to reset the values.
Does it smell like it's running rich? I'd have thought an injector fault would throw up a code. You mention drag - does it feel like it's labouring? No changes in temperatures?
Agree with others about confirming it by fill-up quantities and mileage covered to get an exact figure. I use Fuelly, which works well for me.
Mysterious 🤨 - will be interesting to know what's up.
Gaz
It's now done 31K miles, and the plugs and coils were replaced in April this year during a full service at ~29K miles following a slight misfire, as was the air filter.
The car is a 2019 2.0 TSI SE L.
I don't know what happened Gaz, but the issue seems to have gone away for the time being, though it still seems a little thirstier than previously, but nothing that I couldn't put down to a change of driving style. Last tank mpg was about 44 overall, which is fairly typical. The 50 MPG figures are only when I'm on a long run or am deliberately driving for economy. I've just checked it (without having reset my BST clock yet. 🙄) and a motorway run I did today was just over 50mpg, which is normal for it.
So I have no idea what it was up to for that brief drop in MPG, but obviously I'll keep an eye on it.
Thanks for the feedback, gents. 👍
Maybe there will be better efficiency if it does not get too cold soon and having a while of the Winter Formulation petrol. Maybe more so with the E5 depending what actual octane it comes with better than the min 97 or 99 ron minimum.
I've tried to second-guess myself on the driving style, trying to fit the available data into a theory, but it's very much guesswork, and it doesn't explain the HUGE variation in MPG, given a very similar route driven at a similar pace, traffic permitting. (I'm just driving too and from work, after all.)
Just a thought, it could be the GPF regeneration. It happened to me after several days of slowish journeys. I even called the RAC out thinking there was a fuel leak.
Never happened again.
OMG! I think we have a winning reply!
Perhaps a careless omission from my initial post, but the WAS a hot smell coming from the car the first time I noticed the low fuel consumption. I thought it was a brake binding, and the hot smell didn't repeat for my home journey after that one instance, despite still having that 20-something MPG on that return journey, so I thought it was a red herring and didn't mention it.
My goodness! That would explain why there were no fault codes and the garage found nothing.
I think you have nailed it! 🏆
