cornering foglight
hi All,
I need help
i tried to activate cornering option on my friend's skoda octavia mk III, facelift.
I used this commands:
Controller 09 - Central Electronics
16 - Security Access - enter 31347
10 - Adaptations
Change the channels listed below - scroll to just over halfway down the long list of adaptation channels to find them. Do them one after the other, and do not come out of the adaptations until you have finished. If you do, you will have to close the controller and go back in and enter the security access code again. If on a vRS you only want the outer 2 bulbs to function as cornering fogs, then don't alter the first two channels, just alter the two channels listed as additional for the vRS, which are for the outer two bulbs.
Change (5)-Leuchte12NL LB45-Lichtfunktion B 12 to Abbiegelicht links
 Change (5)-Leuchte13NL RB5-Lichtfunktion B 13 to Abbiegelicht rechts
but it is not working.
The left fog light in always on, indifferent of the steering wheel position, the right foglight dos not power on.
where is the problem?
this is the error mesage,
i put manuali 12345 an 123 but stil no joy
PS sorry for adding a new post but i did not find the edit button
Problem solved !
 this is the lines i change ( with red original values )
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset    0.00 °           0.03°
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit     50.0 %/s       0%/s
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt           both sides    both sides
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold        0.0 km/h      0km/h
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur             100.0 °C        0.0 °C
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur       95.0 °C         0.0 °C
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel          90 °               0.00°
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur      80.0 °C         0.0 °C
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel         30 °               0.0 °
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold         40.0 km/h    0.0 km/h
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift                                   ECE R119   ECE R119
Edited by wildserb
