from 230km/h to 120km/h
i was today drving 230 km/h and my engine didnt pull anymore and i could go just 120km/h.
i turnd off engine started again and everything was ok,
but why did the engine used emergenci mode?
thanks
Probably went into limp mode from the amount of throttle being applied. I assume you had it foot to the floor for over 1 minute to creep up to 230km/h? I know to reach 140mph in mine takes some patience with the foot to the floor.
I think its overboost or something else which triggers the limp mode. Kills the turbo to preserve the engine.
Worth getting old of a VAG-COM and reading off the fault codes if you can. IIRC, Jon had a similar situation in his Octy due to "Maximum engine revs exceeded - warranty void". I believe it may also go into limp mode if the revs are in the red zone for a minute or more....
Chris
Worth getting old of a VAG-COM and reading off the fault codes if you can. IIRC' date=' Jon had a similar situation in his Octy due to "Maximum engine revs exceeded - warranty void". I believe it may also go into limp mode if the revs are in the red zone for a minute or more....
Chris[/quote']
i went right away to vag com and there were no faults.
everything was ok,it just slowered me down
whatever,started the engine again and 230 was back on the speedo hahah
thanks
i should be more carefull next time
