boot light/torch
i have taken delivery of my first yeti
a 2017 2.0ltr outdoor automatic diesel 4x4
there was no torch/boot light so i purchased one from Ebay, when its installed the light comes on nice an bright
the problem is it appears to stay on when the boot lid is closed.is this correct
thanks Ron
On mine the both the normal boot-light and torch-light switch off as soon as the tailgate is closed.
thanks Ron
It doubles as a rechargeable torch so make sure it's switched off and then it will go on/off with the boot.
There must be a magnetic switch in the torch, if on either of the 2 brightnesses the torch switches off when about ½" from putting in the holder.
Mine is a great boot light but rubbish torch.  Batteries are shot. I guess 3 x AAA rechargables will sort it.
Any particular battery chemistry?
Edited by idleness
Ni-MH as they are on almost continuous charge.
1.2v NiMH AAA 300mAh
Thank you
You may need to use a bit of sticky stuff to hold the two magnetic strips in position. The batteries have a habit of repositioning them 🤣
Two?
There is only one in mine unless they are stuck together☹️
Yes there's two mine, I reckon they could be stuck together, its couple of years ago since I opened mine and I think were stuck together.
