Mk2 09 Octavia VRS Limited Edition Front Road springs (1Z3)
Potholes have just broken a front road spring. I am quite happy to replace them myself but...
Where can I get uprated ones in the UK from?
And what percentage increase should I get?
According to the Kilen spring catalogue, the Octavia MK2 VRS uses 1K0411105DB front springs. You can check by looking for coloured dots on the original springs. 1 red dot, 1 white dot, and 1 violet dot, means the front spring has OEM part number 1K0411105DB.
KYB are very reliable springs. Kilen/Lesjofors are also very reliable, but the Kilen/Lesjofors spring that is sold to replace 1K0411105DB is also sold to replace other OEM part numbers, so might not be an exact match to 1K0411105DB.
KYB RH3941
Front coil spring 1K0411105DB
1 red paint mark, 1 white paint mark, 1 violet paint mark L58
https://www.ebay.co.uk/itm/334817170091
Edited by Carlston
KYB RH3941
Thanks but that link is showing not comparable with my car. My VIN is TMBUH2 1Z 392011711
Diesel 2L VRS limited edition 09 170hp estate
I believe it has sports suspension?
Yes, the VRS normally has sports suspension, unless the person who ordered the new car specified standard suspension.
gknautomotive.com list the Octavia MK3 2.0 TDI VRS estate as having 1K0411105DB front springs if the car has a manual gearbox, or 1K0411105DC front springs if the car has a DSG gearbox.
As you can see in the chart below, there are only four possible options for the Octavia MK2 VRS estate with sports suspension.
Build code L58 means the car has 1K0411105DB front springs.
Build code L59 means the car has 1K0411105DC front springs.
You can also go by the coloured dots, ie. paint marks, to check what front springs you have.
The information shown on ebay listings is unreliable. The only way to be sure what the correct springs are is to use the car's build codes or go by the coloured paint marks on the springs.
The spring catalogues from Kilen and gknautomotive.com are also a good source of information, but their recommendations won't always be for exactly the same spring that the car left the factory with. Hence, why checking the car's build codes or the coloured paint marks is so important.
No Part code Title Note QNT Model
    suspension
Shock absorber (spring cyl.)
for vehicles with sports
suspension
Anti-roll bar
    *RS*
estate car:
fr.wheel drv
PR-A8F+2UC
1 1K0411105DA Coil spring
3 paint marks
1 paint mark
red
Grey
2 PR-L55
1 1K0411105DB Coil spring
1 paint mark
1 paint mark
1 paint mark
red
white
violet
2 PR-L58
1 1K0411105DC Coil spring
1 paint mark
1 paint mark
red
violet
2 PR-L59
1 1K0411105DD Coil spring
1 paint mark
2 paint marks
red
violet
2 PR-L62
Edited by Carlston
    suspension
suspension
Anti-roll bar
    *RS*
estate car:
fr.wheel drv
PR-A8F+2UC
3 paint marks
1 paint mark
red
Grey
2 PR-L55
1 paint mark
1 paint mark
1 paint mark
red
white
violet
2 PR-L58
1 paint mark
1 paint mark
red
violet
2 PR-L59
1 paint mark
2 paint marks
red
violet
2 PR-L62
WoW thanks for that...mine is RED/White/Violet
Please can you now tell me the part number I am looking for the Front dampers/struts?
The Octavia MK2 2.0TDI VRS estate with sports suspension only has two options for front shock absorbers, as shown below.
As your car has front springs with build code L58, you can see below that your front shock absorbers have OEM part number 1T0413031HP.
However, the same aftermarket front shock absorbers are often sold to replace both these OEM part numbers. For example, Bilstein B4 22-139191 and Bilstein B4 22-183729. These are currently available on ebay.co.uk and amazon.de for between £57 and £64 each, including shipping.
https://www.amazon.de/-/en/22-183729-Bilstein-Shock-Absorber/dp/B0068MJK0K/ref=sr_1_1?crid=2YIHZ6XH2L5OG&keywords=22-183729&qid=1681589202&sprefix=22-183729%2Caps%2C72&sr=8-1
https://www.ebay.co.uk/itm/232571914844?epid=249562353&hash=item36265dca5c:g:frAAAOSwOZpjOuQc
https://www.ebay.co.uk/itm/332627080714?epid=249100585&hash=item4d721e760a:g:a0sAAOSwBYBj-Nq-
8 1T0413031HP Gas shock absorber
suspension
  2 G07+2UC+L55,L58
8 1T0413031HK Gas shock absorber
for sports suspension
  2 G07+2UC+L59,L62
Edited by Carlston
suspension
  2 G07+2UC+L55,L58
  2 G07+2UC+L59,L62
Thats amazing info thanks..now ordered
The link for the front springs, when I put my car details it said it was not compatible?
KYB RH3941
Do you know why?
KYB RH3941
Do you know why?
Found This, Autodoc any good?
https://www.autodoc.co.uk/sachs/7070584
4 hours ago, Carlston said:
Sachs 993 053 matches 1K0411105DB so should be the same as KYB RH3941.
This ebay listing shows that KYB RH3941 is compatible with a 2009 Octavia MK2 2.0TDI 170HP VRS estate.
https://www.ebay.co.uk/itm/185734727816
Thank you .
