Installing rear view camera
Which pins from my rear light should I use for my new rear view camera?
I really hope you can help.
Daniel
What kind of reverse camera are you fitting that requires a reverse light signal?
Sounds like the wrong part. The correct setup uses canbus and the 5F radio to control it.
Also, as the car has bulb circuit monitoring the wire is never truely 'dead' there is always a small amount of voltage running through to check the bulb isnt blown so this kind of setup does not always work.
