Megasquirt adaptation.
Hello again friends.
Here is the thing: currently I own a carbureted 1.3 Felicia, and I'm on the journey to make it EFI with the megasquirt ECU and got almost everything figure it out, but right now I'm struggling with the crankshaft position sensor, don't know if the original from the 1.3mpi works or should I try an other way,  has any one has donde this? I could use some advise.
Thanks.
Do you have a MPI flywheel?
I'm not 100% percent sure but I think the flywheel on carb. engines and MPI has differences.
There is an alternate solution for crankshaft sensor. Here:
I'm also interested in in carb. to custom ECU conversions so I'll follow your post.
