Kodiaq windows
Hi everyone,really looking for advice and help
so the car is 2022 kodiaq SE L
and holding the key for unlocking didn’t lower my windows…
the function is already ✔️ in the menu
I'm guessing they may all need to be re-synced
Not sure the latest process but it used to simply be all windows fully down and continue to hold down for a couple seconds and then the same for up, holding up for a few seconds past closed.
Don't use one touch up/ down, need to fully depress the buttons and keep hold holding
Thank you, will try later
tbh even the one-touch function not working😂
Just bought the car a week ago
from official Skoda dealer and trying to figure out how works everything
The one touch is likely related and has the same reset procedure...... Presuming it is still the same as above
Thanks for your quick and detailed response to my question
You're welcome, just hope it's the right answer and an easy resolution for you.
Yep, my Superb needs this procedure every 3 or 4 months. Does the trick every time. No idea why though.
