Does VCDS HEX-V2 support rear brake change on Kodiaq
Hi
I have tried to search for this topic. :)
I have a Skoda Kodiaq 2.0TDi 150hk.
I need to change rear brake pads and rotors and open the rear brakes with a diagnosis tool.
I already have iCarsoft VAG2, but get the message "This function is not supported for this vehicle" when trying the caliper options. Worked fine with earlier VW Passats.
So I have decided to buy a Ross tech VCDS HEX 2 3VIN original cable.
Will this product support opening and closing the rear brakes? I know it most likely will support it, but my car part dealers web page informs that my car does not support this product..
I also hope this tool can be used to register/tune in a new car battery with the system.
Thanks for any help!
Erik. :)
Yes to both questions. As I'm looking at the same VCDS HEX2 3 Vin.
  • 4 weeks later...
Thanks for your reply Simon!
Just want to add for others who are also new to using VCDS.
When I connected the cable to the Kodiaq and tried to go to "53 - parking brake" I got an error message.
I was concerned that the cable did not work with the Kodiaq brake system.
But found out that this function is controlled from "03 - ABS brakes".
See guide in attached link:
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_VII_(5G/AU)_ABS_Brakes#Basic_Setting
Erik
