Octavia 2.0 TSI VRS rough/hunting idle
Hi folks, looking for ideas as to what can be causing a rough/hunting idle upon cold start.
A few weeks ago I foolishly drove the car 5-6miles without the oil cap after I'd topped up. I noticed as the car was hunting idle massively whilst driving and could smell the oil burning off as it had sprayed out the cap hole.
Since then I have noticed a rough unsettled hunting idle on cold start. This morning it was so bad it died completely and the start/stop kicked in to correct it. It seems to last for 20-30seconds or until I give it a few revs.
Could I have damaged anything driving with the cap off for 15-20mins? Any sensors etc? It's a 2014 car with about 103k on the clock.
Thoughts appreciated.
I've had a similar issue on and off for a while with mine, same year, but 160k on the clock.
It's possible you've got oil on the sensors for the cam angle on the intake and/or exhaust. One of them is right next to the oil cap.
Take the plugs off, and see if there's oil inside making a bad connection.
I've very inexpertly circled their location here! 20230603_150021.thumb.jpg.99288b693b7d439e8f06b07205801428.jpg
If you have access to vcds or obd11 etc, you can check what the sensors a reading
