Skoda Octavia 2021 1.5 tsi etec dsg7 hot air from air vents
Good evening,
I have a skoda octavia 1.5 tsi etec dsg7
and since I bought it, from the air vents, if I turn on the fan only without ac, at the lowest temperature it comes out noticeably hotter air than the outside and this is very annoying especially in the summer months.
In all the cars I've had, the fan air at the lowest temperature was only a little bit hotter than the outside, but in this car it's noticeably hotter.
An other thing that I’ve noticed is that
at high speeds with the window open,
air comes out of the vents either with the recirculation closed or open with the entire air conditioning system and fans off
As soon as i close the window, air stops coming out, as soon as i open it again air comes out of the vents
With the recirculation closed it makes sense because there is draft with the window open but with the recirculation  open is it make sense that  air is coming out from the vents
And all of this with noticeable hotter air than the outside air!!!
Does anyone else have this problem with this particular car?
  • 4 weeks later...
Hi,
i noticed hotter temperature.
I don't know if it is a defect or no but it is not so good in summer season. You neeed to use your AC more for sure.
