PCB ON STEERING
HI what is the PCB board under the steering Colum called as i need to replace it. had to replace the ignition barrel and broke of the pins off the PCB that it connects to
thank you
thank you
SKODA SUPERB STEERING WHEEL SQUIB SLIP RING  think this is the part
I think this is what you asked for.
great thank you, i will take a look
Does the ignition barrel connect to that?
I thought it was only the parts that rotate with the steering wheel, horn, airbag, steering wheel controls etc.
I  am not 100% sure as I only need the pcb board as the 6 pins snapped off
