Ignition - Start/Stop button
I have started seeing a problem with the ignition stop/start button on my 2018 280. It can work first time or it can take half a dozen attempts to actually turn the ignition on or start the engine. Has anyone experienced the same and a have a solution for it?
There are new batteries in the key fob so I know its not that. Im worried that it might stop working all together and leave me stranded.
There's a thread around here somewhere that shows how to dismantle the ignition switch. The switch gets gunked up and cleaning sorts it.
If I can find the thread I'll reply again 👍
Found it -
Edited by unclerichy
Found it -
Brilliant, thanks for that. Well that's this week's job identified.
I did mine a couple of months ago using JFC’s post. 30 mins from start to finish.
Thought I would get this done today. Super useful guide. Thanks. When I opened the switch it looked really clean. Gave the Pcb a quick rub with some cleaning alcohol and put it back together thinking it wouldn't change. I was wrong, problem solved. First push it kicks in.
