Series of electrical issues
                 Hi everyone, I'm having a couple of issues with myFabia and I'd really appreciate some advice and opinions.         My left and right blinker inidicators are not shown in the dash, while everything works on the outside. Also when the hazard key is on both of the indicators turn on but are completely out of sync. In both cases the clicking sound also can't be heard.              At the same time the aribag indicator is on all the time.    I should probably mention that my battery is brand new.
     I just noticed one new issue. When I turn the key without starting the car, and start the blinkers the battery icon goes off too. 😭
It sounds like your electrical control module has taken a dump, someone will be along who can advise no doubt.
                        https://streamable.com/xffagz
Here it is how it looks if my explanation is bad. Don't mind the windows part, that one is broken  too but I don't think it's    related to the problems in the first post.
If you meant the BCM or CCM as someone calls it, you were right. It took several car workshops and a month to fix. The fix itself was just getting a new (used) BCM with the adequate number, and coding it. The rest was just time wasting. :)
And the best thing is, the window problem I showed in the video was all down to the BCM (also fixed the buzzer for the lights on/door open thingy).
