Cruise Control Fault
Hi everyone,
Wondered if anyone could provide any info/guidance on a problem I am having.
Bought a 14 plate Octavia Elegance 1.6TDI in January 23, everything been fine so far.
My cruise control works fine apart from when I indicate right, it immediately turns off and when I try turn back on I am met with the orange warning sign. This only happens when I indicate right, works fine if indicating left.
If I turn the engine off and then back on CC comes back on straight away. Been a couple of times since this problem that when I turn CC on nothing happens, like it isn't registering, this is after the error light comes up.
The CC buttons are on my indicator stalk.
Do I need a new stalk?
Does it need to be taken apart and cleaned? Or a new switch?
I believe there is different type of stalk which is a separate stalk altogether, just for CC (so 3 stalks coming out of the steering column instead of 2) would this fit my Octavia?
I drive as part of my job and use the CC a lot so I can concentrate on unfamiliar roads without having to worry about speeding. Also use on motorways
Obviously thinking of going to a garage to see if there is an error code that would shed some light on the issue.
But thought I would see if anybody else has encountered this problem.
Many Thanks.
