VCDS challenges
Hi. New VAG owner here, got me an Octavia 2016 5E5. Also picked up an VCDS HEX-V2.
Everything seems to work up until I need to put in security codes. I get the yellow bubble with RossTech tips eg. Security code 31347 for module 09 aso.
But every time I insert code it comes back with an error that the controller refuse the key. I have only tried the Module 9 so far, but nomatter what I type, the error pops up.
Trying to negate light bulb error after switching to "can bus led" on license plate wich while the bulb works, I get an annoing error.
Also I want to be able to "remap" the bixenon headlights wich are way too high.
tips and pointers please..
Log160511km-99736mi.txt
examples
Noone?
Why have you created 2 accounts with slightly different names?
onto your issue - have you tried any other modules to see if the code is accepted? Let us know if other modules work.
also where did you get the vcds tool.
By mistake. I thought I created an account. Tried to log in, failed. So I thought I just made a mistake and created a "new account". I'll look it over and try to delete the other one. Thanks for the heads up.
Bought the unit "new and unused" from marketplace. Should be original, payed premium moneys and I cannot see anything that tells me otherwise..
Have tried to access more of the modules, googled and tried different codes to no avail.
BUT I saw last night that S12345 was case sensitive on the "S", and I'm not sure that I tried that. Will try tomorrow.
But as it stands in not able to do any changes with secured demand, regular long coding works fine.
Is that something to do with the origin of the device itself?
There are a lot of clones.
If it was used there should be a change of ownership fee to pay also, there is also a vin limit.
If you paid less than £200 even used, you’ve got a cheap clone and chances are that is your issue.
Have you downloaded the software from Rosstech and initialised the dongle to register it?
If the software came on a CD then you have a clone but I suspect you already know that.
I bought it for less than €200 so I guess it is a clone then.
Will make a request at Ross Tech for verification on this. If it is a clone I guess I can just forget to get it to work? Looks legit though
Looks legit though
Look at the serial number on the cable, maybe even post it here (Ross-Tech will ask you to do that).
  • Dean locked this topic
Guest
