Superb 3V face-lift 2022 adaptations re-store
Hi
I use VCDS and - reset the adaptations to default.
And I didn't make aby backup before.
Has someone did the adaptation dump to hex and can shere it ?
Details are below.
Greetings.
Address 01: Engine (J623-DTSA)       Labels: None
   Part No SW: 05L 906 022 GS    HW: 05L 907 309 T
   Component: R4 2.0l TDI   H80 2102
   Revision: EBH80---    Dataset Number: V03935380SJ 0001 CVN: 0F2F0E73914A6D20914A6D2043FB2DAA
   Coding: 011904120324050830000000000000000000000000000000
   Shop #: WSC 33000 790 00120
   ASAM Dataset: EV_ECM20TDI01105L906022GS 008001
   ROD: EV_ECM20TDI01105L906022GC_SK37.rod
   VCID: 7EA5FEE540748B2A7DF-802A
   VINID: 91D49A6077A00E01C004814924557609A4
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 GD    HW: 5Q0 614 517 BR
   Component: ESC           H82 0114
   Revision: 00000000    Serial number: 62022000000288 Dataset Number: V03935364FK 0001
   Coding: 1E077A9C31213B74477C060960CC48785E8CDCE2600612753063F578D0024A0B0002010312121212B435351919323200
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049_VW48.rod
   VCID: 79AFEDF9595AAC1248D-802C
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0606244172 Dataset Number: V03935332UP 0001
   Coding: 0F20000623
   Shop #: WSC 00033 790 00164
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 48C9583D5230059A873-801C
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 3V0 907 044 FC    HW: 3V0 907 044 FC
   Component: AC Automat    H34 4901
   Revision: 20K10000    Serial number: 00000B01882923 Dataset Number: V03935340DL
   Coding: 12010104002410011005100100101136
   ASAM Dataset: EV_ACClimaPrehVW37X 002030
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 7AADF2F55C5CA70A417-802E
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 E    HW: 5Q0 907 659 E
   Component: G238 _AQS  H32 0120
   Serial number: 135142554
   Rear air conditioning block 1:
   Subsystem 2 - Part No SW: 3V0 907 049 E    HW: 3V0 907 049 E
   Component: E265KlimaHeck  H02 0201
   Serial number:       06051501850797
   Coding: 000000
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 EB    HW: 5Q0 937 084 EB
   Component: BCM MQBAB M+  H44 0511
   Serial number: 01102222700238 Dataset Number: V03935362PR 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW26.rod
   VCID: 7CA1F4ED5668993A53B-8028
   Wiper motor control module:
   Subsystem 1 - Part No SW: 3V1 955 119 A    HW: 3V1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 290822  039 0122
   Serial number: 00000002208240301075
   Coding: 164DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: SAY22M09D29H08M11S35
   Coding: 0088DF
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY2216003WA
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000002737285
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 KH    HW: 5Q1 953 569 J
   Component: Lenks.Modul  H14 0190
   Serial number: 0100130920220C100685
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H10 0075
   Serial number: 000150058022265 Dataset Number: V03935314JL 0001
   Coding: 8479151041
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_009_VW37.rod
   VCID: 53F37F519B76B642E21-8006
Address 13: Auto Dist. Reg (J428)       Labels:. 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3Q0 907 567 B
   Component: ACC BOSCH MQB H03 0780
   Dataset Number: V03935324MH 0001
   Coding: 2A00604159FFC728949C812400400600000000000000000046
   Shop #: WSC 00033 790 00120
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW41.rod
   VCID: 47CB5B015F2E0AE28E9-8012
No ASAM data for: "EV_ACCBOSCHVW416" (SK48)
2 Faults Found
0858 - ROD - Unknown Error Code
          - 00 [008]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 171
                    Mileage: 3982 km
                    Date: 2023.06.16
                    Time: 16:02:51
1232 - ROD - Unknown Error Code
          - 00 [008]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 5
                    Reset counter: 171
                    Mileage: 3982 km
                    Date: 2023.06.16
                    Time: 16:02:49
Address 15: Airbags (J234)       Labels:* None
   Part No SW: 5Q0 959 655 CF    HW: 5Q0 959 655 CF
   Component: AirbagVW21    010 0421
   Serial number: 003J8R8LA97Q Dataset Number: V03935333L  0001
   Coding: 98CCC0C0000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 0655960518A4D3EA35F-8052
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 480 001 509 22
   Component: SideSensor_Df  001 0887
   Serial number: 357000000007B38C126M
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 480 001 509 22
   Component: SideSensor_Pf  001 0887
   Serial number: 3580000000000149A164
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 480 401 009 22
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001C30B0CA73112T
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 480 401 009 22
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001A2C8C2738A7AG
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 401 009 22
   Component: FrontSensor_D  005 6149
   Serial number: 35500019E9EC8C25F0E%
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 3V0 920 790 H    HW: 3V0 920 790 H
   Component: KOMBI         526 6220
   Dataset Number: V03935374KG 0001
   Coding: 05A5091223800008018C67015801000800600000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001048
   ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
   VCID: 3C2134ED16E8593A13B-8068
1 Fault Found
16776982 - Databus
          U1121 00 [009] - Missing Message
          [SWA_01 keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 96
                    Mileage: 4835 km
                    Date: 2023.06.30
                    Time: 22:05:56
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5502
   Serial number: 09092210800247 Dataset Number: V03935378VY 0001
   Coding: 0B0100045F28730023104240000F00010001070000000000000000000000
   GVL: 01443C0008000608409C80008002480000000000000000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5B03E1477E8222769-802A
   Generator:
   Component: 4-00-05-00-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5E3 919 719 H    HW: 5E3 919 719 H  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H02 0110
   Serial number: PR6-0440061263221791
   Coding: 240000
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H11 9070
   Serial number: 7427090306
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: U13DCAC  H27 0810
   Serial number: 2329088
Address 23: Brake Booster (J539)       Labels: None
   Part No SW: 3Q0 909 059 AF    HW: 3Q0 909 059 C
   Component: EBKV          H09 0209
   Serial number: BPA085220922013 Dataset Number: V03935367PB 0001
   Coding: 0102C140300000C618638C31000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 015024
   ROD: EV_BrakeBoostG2BoschVW48X_015.rod
   VCID: 7BA3F7F153669E025A1-802E
1 Fault Found
108400 - Immobilizer Control Module
          U0167 00 [032] - No Communications
          [NoVINDetected]
          Intermittent - Not Confirmed - Tested Since Memory Clear
Address 2B: Steer. Col. Lock (J764)       Labels:* None
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H10 0040
   Serial number: 22000218113005 Dataset Number: V03935342UT 0001
   ASAM Dataset: EV_ELVMarqMQBA0 002004
   ROD: EV_ELVMarqMQBA0_VW48.rod
   VCID: 323D1AD5C4AC9F4AC97-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 F    HW: 5Q0 959 760 F
   Component: Sitzmemory    H10 0026
   Serial number: Y0007VID36508 Dataset Number: V03935343ZD 0001
   Coding: 0018000000000500018280808080000000008181000000D440
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide.rod
   VCID: 40D9401D7A003DDA4F3-8014
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000480343873  Dataset Number: V03935378DE 0001
   Coding: 00118820DE00020000001100
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
   VCID: 52FD7A55A46CBF4AE97-8006
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 276051 00  Dataset Number: V03935310FE 0001
   Coding: 0100001000400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_AU37.rod
   VCID: 2B0307B1E386CE828A1-807E
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000480245904  Dataset Number: V03935378DD 0001
   Coding: 00118020DE00020000001100
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
   VCID: 51FF7559A16AC452D0D-8004
Address 5F: Information Electr. (J794)       Labels:* None
   Part No SW: 3V0 035 820 L    HW: 3V0 035 820 L
   Component: MU-O-ND-EU    H22 0306
   Serial number: SKZAZ2A0432996  Dataset Number: V03935377LP 0001
   Coding: 34820000000030000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_SK48.rod
   VCID: 372B2BC12FCE7A62FE9-8062
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Dataset Number: V03935342ZE 0001
   Coding: 0484020182002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
   VCID: 392F2DF919DA6C1208D-806C
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5WC 959 107 A    HW: 5WC 959 107 A
   Component: HDSG-Modul    H05 0433
   Revision: --------    Serial number: A2-C767-1160-8 Dataset Number: V03935356FX 0001
   Coding: 0D08
   ASAM Dataset: EV_DeckLidCONTIAU536 001002
   ROD: EV_DeckLidCONTIAU536_VW38.rod
   VCID: 4FFB7321B75ED2A2C69-801A
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 5WA 035 284 G    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0143
   Serial number: 0000000209VIMU5 Dataset Number: V03935383VW 0001
   Coding: 034820101969A8819005460161012E07
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW41.rod
   VCID: 4ACD62354C3CF78A917-801E
1 Fault Found
7193 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Lane Departure Warning Heading Control (0x19) - Funktionseinschr�nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 4835 km
                    Date: 2023.06.30
                    Time: 20:06:09
                    Voltage terminal 30: 11.7 V
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1401
   Serial number: EA1567404222720 Dataset Number: V03935374FB 0001
   Coding: 0002089811484020080500000020002001008000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW41.rod
   VCID: 363526C528C4836AE5F-8062
1 Fault Found
1124116 - Internal Fault
          B200F F0 [008] - Unknown Error Elaboration
          [SPI_communication_to_EyeQ_timout]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 9
                    Reset counter: 38
                    Mileage: 1418 km
                    Date: 2023.05.07
                    Time: 18:05:04
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q4 959 595 P    HW: 5Q4 959 595 P
   Component: TSG HFS       008 0911
   Serial number: 0000478587138  Dataset Number: V03935351WH 0001
   Coding: 001080208000020000001100
   ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 54F17C4D9E78B17AFBB-8000
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      008 0911
   Serial number: 0000478604764  Dataset Number: V03935351WF 0001
   ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
End----------(Elapsed Time: 01:34, VBatt start/end: 12.1V/12.1V)-----------
What do you mean you reset adaptations to default?
and if you mean adaptation channels have all had their values messed with (not that I’m sure how you’d manage that) every single car will be different and you can’t just take someone else’s adaptation channels and put them on your car
Basically, the solution was to get in the car and drive a few miles.
It seems that clearing the adaptation parameters does not require a visit to the website, as someone claimed on the forum, which caused me to panic.
And yes, copying settings from another car would be stupid or at least crazy, but as everyone knows, no risk, no fun.
Given that my car is quite lazy on the road, so maybe adaptation modifications would help.
I saw that some people change the brand type from SKODA to VW via VCDS and the card becomes more flexible.
Regards.
you are getting confused between adaptations and adaptions.
adaptations are the cars settings
adaptions are dynamic values the car adjusts depending on certain things like driving style and such.
