Alarm going off
Hi all , alarm keeps going off on fabia scout .
Can i just pull fuses to disable it and leave them out ( at my own risk of course)
D
Take the fuse board cover off, there is an icon that looks like a person running away from a sound wave. That will be the fuse to silence it.
It won't stop your indicators flashing though whilst alarm is going off.
Had the same issue on mine, had to replace the siren which is located under the wiper arms on the scuttle bulkhead, about £200 to replace the siren.
Great thanks .
I take it doesn't affect central locking?
D
Not that I recall, could still lock and unlock the car. Warning light on the door card may not illuminate or be permanent on - indicating a fault on the system.
Ok cheers
D 👍
Some replace the battery in the siren.  Threads showing how to if you look.
Well there was 2 fuses in handbook , i took 54 out  but 20 also said alarm. im guessing as 20 was in grey it was the LH drive fuse board.
Anyway i sat it car , locked doors them waved arms around after 30 secs and nothing happened, not even indicators flashed so im hoping that 54 is the correct fuse.
D
