Fabia Alloys, dust caps stuck on?
Hi all,
Daughjters has a 1.9SD fabia with alloys. Can't get the dust caps (metal) off the valves. Don't want to rip the valves out by applying excess twist with pliers. Any thoughts? Be kind of nice to check the pressures!
Try holding the valve stem with pliers :eek: not to hard though or you will crush the valve....Failing that bring it to me and i will put new valves in:D
Phil
Hot water
Squirt of WD 40?
