Off-road mode adding
Hello, I would want to activate the Off-road Mode(with all function: Hill Descent, settings of ABS...) with the VCDS on a Kodiaq MY19 2.0TDI 4x4 Style. I have the Driving Mode selector button, but do I need the Off-Road button for that mode? Does Off-Road mode require Dynamic Chassis Control? Does anyone know the coding for this and have tested?
You might be out of luck...
All 4x4 variants in the UK come with the off-road mode, which narrows down the potential of finding someone on here that has done this.
But yes, there is no way of selecting it through the normal drive selection menu/button - it needs the off-road button to activate. Whether or not you can get around this is another matter.
And no, it doesn't require dynamic chassis control - that's just adaptive suspension (soft/normal/hard), nothing more.
Thank you Yogi-Bear for your replay!
I will search the internet for more info and to see if somebody coded and tested without the button. If not, i wil go an buy the console with the off-road button.
If i find something interesting I will post here to help others.
