Crack in the sunroof plastic chassis - MK3 2016
Hello everyone,
latley i had some water enter the car from the front pilar both side.
iv checked the sunroof drain are not clugged and its not.
what i did notice is a crack in the sunroof plastic chassis.
any idea how to resolve it?
does glue will be enough?
anyone ever encountered this?
Hello, welcome to the forum. I'd suggest a through clean of the full length, then a quality flexible, adhesive sealant - making sure to get it right up into the corners beneath the flexible seals.
Thank you.
anyone know what sort of plastic is it or how can i find out?
so i can find the correct sealent.
4 hours ago, YepYep123 said:
Thank you.
A Polyurethane adhesive is probably your best bet - strong adhesion, waterproof and flexible.
to be extra sure I’d get a 3M plastic adhesive primer first, else it’s gonna be a complete sunroof setup
thank you.
Polyurethane adhesive fixed it.
