O.B.D code po753
Recommended Posts
Hi guys im getting code po753, suggests on internet,The P0753 code indicates that the shift solenoid in transmission shift solenoid A is faulty does anyone know if its an external FIX you can do yourself or is it in the gearbox [garage job] sounds expensive,any help or advice would be much appreciated.
Link to comment
Share on other sites
Thankyou i have taken the car to an Automatic Specialist YESTERDAY who done a diagnostics and told me the same thing i already new code po753,he wants to book in for further investigation,im told it could be low oil in gearbox,bad tcm or transmission solenoid,the thing is the problem is intermittent,the gear reading display on the dashboard shows p.r.n.d.s and the number gear you are in and totaly works and drives fine,another time you will get into vehicle prnds all blacked out and no gear number showing, and limp mode,could this be a low oil if it was would it show on dashboard as a warnig light,could a faulty tcm,effect the operation of the transmission solenoid,or could it just be the solenoid causing all the problems,in which case why would the car run approx 5 miles perfectly before it goes back into limp mode,what would you do,and where should i start.ALSO IS THE SOLENOID IN THE GEARBOX.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
