Cost of Rear Dampers 😳
Hi all, I’ve just been quoted nearly £600 to replace both rear shocks? Is that the price these days? Holy crap that was a surprise.
anyone had them changed recently?
Are they DCC dampers? (Dynamic chassis contol) - they have an electrical plug on them.
If not, go to a trusted independent and they should cost less than half that.
Are they leaking or simply misting a little? Misting is not an MOT failure and is considered normal.
Not that I’m aware as ŠKODA never mentioned DCC.
They are leaking, this was shown during a service I had done on the weekend. I can really tell with the handling too. Has made a huge difference.
Thanks for your help.
If they are non DCC that is way too much. Shocks are around €200 (Monroe) and fitting is straightforward. Should be more than €400.  No need to bring this to Skoda, any independent can fix this for you.
Monroe shock absorbers are ^&*() in my opinion. They are the worst thing skoda decided to fit to their superbs.
You could buy a full set of mini special actives for that. 100% do that and it’ll improve the ride quality no end
Say what? Link to whatever those are?
Haha koni special actives
Get an Indy to give you a price for bilstein b4 (oem spec) and new rubber bump stops/mounts. Do check the condition of the springs too as they can rust and snap or just get tired. The labour is most of the cost.
£600 feels like the price for a full set of springs/dampers all around, albeit that might be a bit higher these days.
Edited by cheezemonkhai
Another vote for the Koni, I only paid around £700 for a set of four plus fitting and they made a huge improvement to the handling.
Mine DCC & I fitted Bilsteins from ML performance - they are brilliant.
