Octavia Mk3.5 4x4 Lift Kit Confirmed Fitment!
Hi All,
Just to say I have successfully had the following kit fitted…. Raises the Ride height by about 30mm. I have an L&K Octavia estate with the 4x4 but not a scout model. Wanted that extra ground clearance as not afraid to use it on the odd occasion off road if needed. Also on the way to work often come across some large floods/puddles so this would help.
Done over 500 miles since having them fitted, and make no difference to the ride comfort and haven’t noticed any issues with handling.
I am Running 225/50 R17 Michelin Cross climates as well, Informed insurance about the lift and no additional charge.
Fitting Kit:
https://www.darksidedevelopments.co.uk/products/mk7-platform-mqb-platform-30mm-lift-kit.html
  • 1 year later...
Hi TubaMagna8, I have a 2016 octavia scout and am tempted to add this lift kit.
Have you had any issues with camber or alignment after fitting? Ive read the camber is effected and there is no camber adjustment?
can this be used on a 2018 Scout? What would it (typically) cost to get a garage to fit it?
