Skoda Rapide Sports Service
My last Service was at end of April 2033
A warning came on a week ago that I need an oil check and service within 28 days
Now 21 days
Is this a full service
What is covered in a full service
Do I wait until end of April
Or get it done in 21 days time
I have only done 8000 miles since last Service
Car Reg date is 2016
I'm thinking of getting it serviced in a non Skoda Garage
Any downsides to this
2023?
If it was reset then the Oil & Filter service should be due in 372 days / 9,400 miles if on Fixed Servicing.
Get it serviced where ever is good for you and they do actual work.
No such thing as a Full Service other than the BMW / Merc ones that were the Big Service.  All Fluids, Belts, Bulbs etc etc.
So maybe a Major, or an Oil & Inspection with Extended Scope.
So when were the Spark Plugs changed, the brake fluid, the pollen filter, the air filter. ?
Bottom green chart the old way they were, Minor / Interim & Major time about.
1039190636_Screenshot2021-09-29at07_53_36.jpg.994d2b104123865330d493df0f73629e.jpg.469b173dd8ff2b7c1980f902f406fe61.jpg
1025295341_Screenshot2021-09-29at07_53_17.jpg.f3e4a6dc63cb89105f9b1ac440bb1614.jpg.1a83aff70ed152245067b78901bec0e3.jpg
1179912860_922218293_Screenshot2022-09-2115_58_57.jpg.3711dc86397a804fc83f268add4ae736(1).jpg.606196879c2532f67305f1ec411800c6.jpg.ae72883e03ebfe07c56e6881a86e16a9.jpg
827614452_SkodaFixedPriceServicing.JPG.3dbea7606c029076ed94e2f0216199b6.jpeg.689c25a185d90e4e44889f342770023b.jpeg
Not sure what you mean by 2023 ?
The car was last serviced at the end of April 2023
The warning now says
Oil check and service required by 21 days
I'm assuming this is the annual service
In April 2023 the following items were completed
Oil Service
Spark Plugs
Brake Fluid
Plus
Cambelt
Do I just do the above again
But not Cambelt
As the item you mention
Oil and inspection service
Car is now about seven years old
Mileage is about 33000 miles
Look at the first line of your post, you put 2033,  so i posted 2023?
We need to assume it is the Annual Service coming up after 9,400 miles or 372 days if it was reset at the last service.
But if it was on Variable 2 years ago and not reset 12 months ago then it could be coming up for in 21 days.
If the stuff above was done a year ago then it is a Oil & Inspection service needed.
Oil & Filter, maybe the pollen filter if not changed last year.
The spark plugs are every 4 years or 40,000 miles so not needing done again.
The brake fluid every 2 years if it needs changed, it can be tested.
The Cam Belt interval is no longer at 5 years or 50,000 miles.  more like at @180,000miles, and many many years.
You just need a simple Oil & Filter Service and inspection and do not get ripped off and the Service Indicator set to Fixed Service Intervals.
Look at the Air Filter and see if clean / fresh, it might need replacing.
Edited by Rooted
Thanks Rooted
My error re date
Hadn't noticed it
I spoke to Skoda Garage
It's the annual basic oil change and new filter and an inspection
Don't need to do brakes or sparkplugs until next year
Said it would cost £225.00
What's your thoughts on this
They have full service history
The other garage I have in mind will not have this info
Do you think this matters
Thanks for your previous help
@Jockster52  personally i do not think there Full History or check tick list is worth much.  Not worth £225 for and Oil change and look see.
I prefer an Invoice and receipt from local garages that do stuff to the car.
The Spark plugs are each 40,000 miles, why would they be due next next year unless that is 40,000 miles since the last change.
Pollen filter area cleaned and a filter fitted matters, or a shake and vacuum and at least checked, same with the Air Filter.
