How to find my DSG gearbox code
Hello all as above how do I find my DSG gearbox code, I have a 2.0 cr 170 engine code CFGB, I can’t seem to find my gearbox code as wanting to find a replacement unit
thanks Shaun
Hi there.
It should be on the code sheet on the first page of your service book.
Or in your spare wheel well in your boot.
If I remember rightly.
Thanks hopefully it will be in my service book, already checked the spare wheel well it wasn’t there, thanks for the reply 👍
If you have a 6 speed wet clutch is likely to be a DQ250.
Mine recently had a service.
I hope your code sheet is where mine is.
Mines playing up…. Going through gears fine until 4, then to get it to go into 5th or 6th I have to use semi auto…. I’m a vehicle technician but I know bugger all about DSG, and ringing around some of my mates they all seem to say they don’t touch them, mechatronic unit was a suggestion, plugged it into my autel and it didn’t come up with any mechanical fault
I had to get mine serviced at the dealer as my local indys don't deal with them.
They are very tricky to work with.
Mine has always been silky smooth thankfully.
Good luck mate.
Mine was for over 200k and I’ve always had the DSG service done what a bugger, luck is exactly what I’ll need 😭
