DVD burning problem
Hi people, i've recently got an external DVD writer for my laptop but when i try to burn a disc it fails a lot,if you do a cd or a small data disc it works fine but if you do something bigger it comes up with a reset error
the laptop is an advent 7012 running nero
heres a failed log
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 17:21:30
Nero Version: 6.6.0.6 (Nero Express)
Recorder: Version: 1.37 - HA 2 TA 0 - 6.6.0.6
Adapter driver: <> HA 2
Drive buffer : 2000kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: Version: AZ16 - HA 1 TA 0 - 6.6.0.6
Adapter driver: HA 1
=== Scsi-Device-Map ===
DiskPeripheral : HITACHI_DK23DA-40 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : MAT****A CD-RW CW-8121 atapi Port 1 ID 0 DMA: Off
=== CDRom-Device-Map ===
MAT****A CD-RW CW-8121 D: CDRom0
PIONEER DVD-RW DVR-110D F: CDRom4
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 36700160 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 223MB (228848kB)
Free physical memory: 135MB (138840kB)
Memory in use : 39 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
18.5.2006
ISO compilation
21:45:05 #1 Text 0 File Isodoc.cpp, Line 6168
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
21:45:05 #2 Text 0 File Reader.cpp, Line 127
Reader running
21:45:05 #3 Text 0 File Writer.cpp, Line 122
Writer PIONEER DVD-RW DVR-110D running
21:45:05 #4 ISO9660GEN -11 File geniso.cpp, Line 3286
First writeable address = 0 (0x00000000)
21:45:05 #5 Text 0 File Burncd.cpp, Line 3155
Turn on Disc-at-once, using DVD media
21:45:05 #6 Text 0 File DlgWaitCD.cpp, Line 257
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2242223 (498:16.23, 4379MB)
21:45:05 #7 Text 0 File DlgWaitCD.cpp, Line 269
Write in overburning mode: NO (enabled: CD)
21:45:05 #8 Text 0 File DlgWaitCD.cpp, Line 2311
Recorder: PIONEER DVD-RW DVR-110D, Media type: DVD-R
Disc Manufacturer: MCC 03 - RG20
Disc Application Code: 64, Disc Physical Code: 193
21:45:05 #9 Text 0 File DlgWaitCD.cpp, Line 431
>>> Protocol of DlgWaitCD activities: <<<
21:45:05 #10 Text 0 File ThreadedTransferInterface.cpp, Line 829
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2242224 (2242224) = #2242224/498:16.24
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2242224 blocks [PIONEER DVD-RW DVR-110D]
21:45:05 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1042
Prepare recorder [PIONEER DVD-RW DVR-110D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4592074752, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2242224 | lead-out | 1 | 0x41 | 0x00
21:45:07 #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
21:45:07 #13 Text 0 File Burncd.cpp, Line 4042
Cache writing successful.
21:45:07 #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
21:45:07 #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 4x (5,540 KB/s)
21:45:08 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2604
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
21:45:08 #17 Text 0 File DVDR.cpp, Line 2300
Recording mode: Sequential Recording Mode
21:45:08 #18 Text 0 File Mmc.cpp, Line 21079
Set BUFE: Buffer underrun protection -> ON
21:45:08 #19 Text 0 File DVDR.cpp, Line 2441
Start write address at LBA 0
DVD high compatibility mode: Yes
21:45:08 #20 Text 0 File Cdrdrv.cpp, Line 8332
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
21:45:14 #21 Text 0 File Cdrdrv.cpp, Line 1284
21:45:14.826 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:45:47 #22 Text 0 File Cdrdrv.cpp, Line 1284
21:45:47.993 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:45:48 #23 Text 0 File Cdrdrv.cpp, Line 1284
21:45:48.424 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:47:00 #24 Text 0 File Cdrdrv.cpp, Line 1284
21:47:00.898 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:47:01 #25 Text 0 File Cdrdrv.cpp, Line 1284
21:47:01.419 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:47:02 #26 Text 0 File Cdrdrv.cpp, Line 1284
21:47:02.130 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:47:02 #27 Text 0 File Cdrdrv.cpp, Line 1284
21:47:02.561 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:48:15 #28 Text 0 File Cdrdrv.cpp, Line 1284
21:48:15.035 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:48:15 #29 Text 0 File Cdrdrv.cpp, Line 1284
21:48:15.465 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:49:27 #30 Text 0 File Cdrdrv.cpp, Line 1284
21:49:27.930 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:49:28 #31 Text 0 File Cdrdrv.cpp, Line 1284
21:49:28.360 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:50:13 #32 Text 0 File Cdrdrv.cpp, Line 1284
21:50:13.355 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:50:55 #33 Text 0 File Cdrdrv.cpp, Line 1284
21:50:55.275 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:50:55 #34 Text 0 File Cdrdrv.cpp, Line 1284
21:50:55.716 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:50:56 #35 Text 0 File Cdrdrv.cpp, Line 1284
21:50:56.407 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:50:56 #36 Text 0 File Cdrdrv.cpp, Line 1284
21:50:56.837 - PIONEER DVD-RW DVR-110D\H2 T0 : Queue again later
21:53:27 #37 SCSI -1114 File Cdrdrv.cpp, Line 1432
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x05490000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x0D 0xC8 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x06 0x46 0xD1 0xBC 0xBC 0x0B
0x18 0x3C 0xF7 0xD4 0x29 0x00
21:53:27 #38 CDR -1114 File Writer.cpp, Line 311
Reset occurred
21:53:27 #39 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
21:53:27 #40 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
21:53:27 #41 Text 0 File DVDR.cpp, Line 2682
EndDAO: Last written address was 903327
21:53:28 #42 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 4x (5,540 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 11/03/2005 23:28:13 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 03/08/2004 23:59:44 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
it was initially in an icy box and connected via the usb port and it didn't work so i then fitted it into a different box which connect via the firewire port but it still fails,i've tried burning at slower speeds but its still the same,i can only assume my laptop is not good enough to run it or that there is a software problem,any advice would be greatly received,i don't know much about computers so keep it simple:O
or if not i'll get a friend over to have a look at the advice and see if he can understand it
regards
Dan
I had exactly the same problem using Nero.
Try downloading Slysoft Any DVD (free trial) to see if that works.
Also try using a different manufacturers media, some drives and media don't play nicely (God knows why)
