pano sunroof issues
Hi i hope someone can help
recently had an issue with the sunroof on my 2016 yeti, basically i tried to open it when it was frozen, terrible crunching sounds then managed to stop it. Worked out how to close it manually
and when it went into service they did a basic recalibrate, which sort of works, but i dont have the tilt feature, which i use all summer, and the other settings are all over the place.
Is there at start position for the motor? How do i find it ? Is there an advanced calibration i dont know of ?
TIA
Sounds like it's stripped some gears.
Hi Urrell
I wish it was that simple, I've  had motor out and no stripped teeth, also found cheap fix for gears if needed .
