PHEV radiator fan starts after engine shutdown
Hi All,
I noticed on my Octavia RS IV PHEV after a longer but soft run (3.3 l/100km and 2kwh/100km consumption) right after stopping the engine the fan would come on but stop immediately. (HV battery 3%)
If I plug in the charger, the radiator fan starts immediately and runs a few minutes with the fan speed gradually slowing down to zero.
Also to note that my home is located on a hill going like 800m on slow speed between 10-30 km/h
Other times running motorway, after stop, no fan on even on constant 120km/h for an hour or so.
All these on moderate ambiental temperature 15-25 C
I am thinking about occasions when engine could not cool down enough due to different situations and needs the engine and turbo to further cool down.
Also, the car in hybrid mode always turn off petrol engine when no throttle which would be normal but not if hot.
So why is the car turning off the petrol engine if the engine is hot and would need to run at light speed to cool it down? Maybe the speed not enough to cool it anyway? If so, why isn't it running the fan after stop the car only with charger plugged in? Isn't it more important to cool the engine down?
Edited by axw
That is normal, don’t wory about.
Thanks!
  • 2 years later...
Hello my friend. It was really normal or u had problems later?
