Successful cruise control retrofit in Facelift Fabia NJ3 MY2020
Hello,
as I have severe trouble retrofitting a cruisecontrol system to out Fabia NJ III Facelift, I'd like to know if anyone of you has ever done this successfully --> please refer to the facelift.
Skoda Europa and dealers refrain from retrofitting it to FL models from MY2020.
So dealers do not program any SWAP Codes for CC activation anymore (at least our dealers so not do it). Thiswas the case with prefacelift NJ3 models.
I don't understand this, as technology hasn't changed significantly afaik.
Column stalk switches are evaluated directly by the BCM Module, my VCDS can evaluate the switches successfully, also activating the CC has worked.
Still I get errors from the column stalk E45 (imvalid signal)
Ours is a 3cyl. 1.0TSi 70kW, Cool Plus (no Multifunction steering wheel, no Limiter, just Air condition, larger infotainment, and Midline Cluster with MFA black/white)
If anyone has successfully coded a cruise control retrofit to a Faceifted NJ3, please let me know, maybe also the way to get there...
thanks !
Christian
nobody I guess?
You could try asking @ApertureS He might spot this tag.
Edited by Warrior193
correction
