Virtual cockpit plastic frame
Hi guys. Can I check how to remove this plastic frame from the virtual cockpit? It’s making plastic noise and I would like to do something about it. Thanks!
 Hi I did it like this
STP2.thumb.jpeg.3e1ea626eb0d460bbf137d469c40a077.jpegSTP1.thumb.jpeg.cdae168ccc24f8efe3fda24e4691db63.jpeg
Edited by GiscoYeti
How tightly did the claws grip? Did you reach under with something
Thank you
To be honest for a car that has been in production for 5-6 years I don't know why they haven't solved this issue, my 2025 MC also has noise coming from this and it's very annoying, I temporarily fixed it by showing 2 small pieces of rubber to the right and left of the plastic and that solved it for a while but it has returned so I think I might need to find a thicker material or ring the service center to get it fixed.
GiscoYeti I'm trying to remove the plastic frame as well for the same insulation issue. It was easy to remove the top steering column cover, but I couldn't remove the plastic frame. Do I have to pry from a specific point or pull with force? How did you manage to remove the plastic frame exactly?
11 minutes ago, hmanzak said:
GiscoYeti Sto cercando di rimuovere anche il telaio in plastica per lo stesso problema di isolamento. È stato facile rimuovere il coperchio del piantone dello sterzo superiore, ma non sono riuscito a rimuovere il telaio di plastica. Devo fare la preda da un punto specifico o tirare con forza? Come sei riuscito a rimuovere esattamente il telaio di plastica?
I also removed the steering wheel, but it is not necessary to act in the direction of the arrow.
Schermata 2025-11-18 alle 11.11.25.png Schermata 2025-11-18 alle 11.09.39.png
Thank you, prying tool provided a great tip. If someone is still looking for an answer, I was able to remove the frame with a plastic tool, starting from the inside and prying a little bit at each corner. Comes off easily without much force. Now I'm looking for an insulation material to use; open to suggestions.
This little tool did the trick.
