Windscreen washer pump replacement
Car is now five years old and the windscreen washer has stopped working front and rear. The wipers still work so from looking on here I surmise the pump has died.
How do I get to the pump? Is it located below the washer fluid reservoir. How much dismantling.
I don't need to use the car every day so I can afford to take off the old pump before ordering the replacement.
Car is a Mk3 facelift.
I think you will need to take off the inner wheel arch lining to gain correct access.
Here are some pictures.
Thank you Mr Plantman. May your beds be well watered 💦
