Lane assist camera
Hi everyone, I mounted the camera for lane assist, the camera is not coded, can someone backup theirs and help me? Many thanks to anyone who can help me. I have obdeleven for the coding
It's not that simple, you need the proper boards to calibrate the camera.
(I assume you already changed the windscreen as well?)
yes the camera is already mounted and wired, all that's missing is the encoding and then the calibration
Edited by soni
with this you will succeed!!!Schermata2024-08-05alle09_15_03.png.4ded47953f76add957ec9fc6374a6c74.png
this is for calibration but before calibration I have to do the coding, do you have a skoda superb with lane assist?
which year, what camera? 5Q, 3Q or 2Q?
2016 3q
Superb 2016 camera 3q
You have Odis Engineering?
No i have obd eleven
if the camera is new, you also need parameters for it.
yes it's new, can the parameters be entered with obdeleven?
no need to be done with vcp or odis-e
Which index letter is your camera?
Below is basic coding without lane assist. Use this and then code lane assist, traffic sign recognition and high beam assist afterwards.
Coding: 0204080200000401002223458040A00010000E100000
A quick google gave a selection for different lcodes for a 3Qx camera fitted to a 2016 Superb.
020408020000040100261345C050A10010000E100020 https://forums.ross-tech.com/index.php?threads/25322/
0204080200000401002223458040A00010000E100000 https://forums.ross-tech.com/index.php?threads/17752/
020408010000010100221346C046800090000E100020 https://forums.ross-tech.com/index.php?threads/25972/
020408010000040100062346C040A00098000E100040 https://forums.ross-tech.com/index.php?threads/42545/
This is my camera
