Background lighting Skoda Kodiaq 2024
Hi does anyone know if the Background lighting can be seen during daylight or if this is a nighttime feature only?  It lights up in the daytime when I open the door and then it goes off, or at least it can't be seen. Its probably the worst Ive ever seen by way of ambient lighting. Thanks
  • 2 months later...
There are settings in the infotainment that invite you to switch it off, switch it manually or to leave it in Auto. Most common is Auto whereby it should show the footweel and side door internal strips when the car external lighting is on. Beware losing the system in the infotainment system as it often is unrecogniseable - particularly after infosystem updates. When you "reset" the light sytem it returns and it works fine, but when you go back to change colour or adjust brilliance, etecetera... don't be too surprised to see it missing again, in the menu. Its a fault but Skoda will argue that by resetting it it works - but only for it to disappear again later.
