High Beam Assist issue
Hello,
I was driving yesterday night on the road with no light and I have activate the automatic high beam and after 60km/h has gone on but when I have encountered another vehicle from another side the high beam has not changed to low beam and I had to intervein for safety. I have check on VCDS and every thing was ok, no fault code nothing.
In the past I have try' d to activate the traffic sign recognition but without any success. The reason way I tray is because I have seen that bellow the mirror is installed an camera.
After that I have seen that is not working and I can not connect to A5 block I have reversed the coding' s done until then but I am afraid that maybe I forgot to do something.
Maybe some of you guys has any idea way is doing ( or not doing ) how suppose to do?
There are 2 different cameras fitted depending on specification (high spec which is at address A5, or low spec which is at address 20) - do you have a camera at address 20?
I think it is, I do have access on this Block and I can do coding or adaptation, on the other hand on A5 I can not go in, it means that I have an low spec camera?
If so, what is wrong with it or I have done something wrong?
I have get an adapt map from Block20 maybe is helpful
adpmap-20-57A-857-511_20240819-0746.CSV
You need to use the correct coding & adaptation changes for the 20 camera that is fitted to your vehicle NOT the coding & adaptation changes that only apply to the A5 camera that you don't have!
The changes needed for the 20 camera can be found in the sticky posts in this forum, I know they work because I did them on my previous Octavia Elegance which had a 20 camera.
I keep looking for it but I haven't find' it, do you remember the name of the topic?
Try here
I have found something but not for channel 20 that is ok for me I have fond for A5 channel.
A lowline camera at address 20 cannot support TSR or lane assist. I would suggest checking your coding log to ensure you've reverted all the changes correctly.
If you still have issues, update your VCDS to the latest edition: https://www.ross-tech.com/vcds/download/current.php
Then post a full autoscan, the coding log and adaption maps from 09, 20 and 5F :)
I am trying to make the high beam working right because is acting strange. The main think is because is not going on low beam when is light outside ( from street illumination ), or when an car is coming from other side, or when I am encounter an car in front. I need to intervene to put manual on low beam, although when I go below set point of speed the high beam changes on low beam.
I will try to get the adaption maps from block's mentioned, but I do not know if i will can get also the coding's.
19 minutes ago, lukik said:
I think it will be needed also this:
Monday,19,August,2024,08:21:38:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.0.0  HEX-V2 CB: 0.4631.4
Data version: 20230228 DS346.1
www.Ross-Tech.com
Mileage: 250865km-155880mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 20 42 44 52 5F 69
VIN: TMBJG7NE3J0304390   Mileage: 250865km-155880miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-DDYA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 GT    HW: 04L 907 445 E
   Component: R4 1.6l TDI   H01 4122
   Revision: 22005001
   Coding: 01114012443419090000
   Shop #: WSC 62430 004 1048576
   ASAM Dataset: EV_ECM16TDI03004L906056GT 004005
   ROD: EV_ECM16TDI03004L906056GT_004_SK37.rod
   VCID: 0557910925A2D8F23C5-8050
   VINID: 91D49A5C77950DA0030040C900BBF98650
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 CP    HW: 5Q0 614 517 AB
   Component: ESC           H25 0323
   Revision: 00000000    Serial number: 60538000000437
   Coding: 2507629114200970407A060960C324A446289002600624723043F070C002430B00000012121212B835351919323200
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
   ROD: EV_Brake1UDSContiMK100ESP_037_SK37.rod
   VCID: 015F8519318AF4D200D-8054
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5E0 907 044 AQ    HW: 5E0 907 044 AQ
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 02010104000110011005000800101022
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 74B1DCCD7E38D17A1BB-8020
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BL    HW: 5Q0 937 086 BG
   Component: BCM PQ37BOSCH 034 0245
   Revision: --------    Serial number: 865802031801NL Dataset Number: V03935276SP 0001
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 018001
   ROD: EV_BCMBOSCH_018.rod
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5E1 955 119 A    HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 180220  051 0916
   Serial number: 887353F0401805102830
   Coding: 164DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  047 0105
   Serial number: S9Y18M03D13H14M35S09
   Coding: 00885D
   Humidity sensor: interior:
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0044
   Serial number: 000308418018058 Dataset Number: V03935256AD 0001
   Coding: 0471051141
   ASAM Dataset: EV_EPHVA18AU3700000 009035
   ROD: EV_EPHVA18AU3700000_009_VW37.rod
   VCID: 4BC367314346EE82AA1-801E
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Dataset Number: V03935261BL 0001
   Coding: 2B00600941FFC728949C810500400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 3E253EE500F44B2A3DF-806A
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4P4M8SB8 Dataset Number: V03935266KC 0001
   Coding: 98CCC000000000005C5400CC000800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 454 002 802 18
   Component: SideSensor_Df  008 0887
   Serial number: 35700000000CD6C85E21
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 454 002 102 18
   Component: SideSensor_Pf  008 0887
   Serial number: 3580000000080A3D6D2S
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 454 802 202 18
   Component: SideSensor_Dr  301 0148
   Serial number: 351000FC1BC13000000L
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 454 802 302 18
   Component: SideSensor_Pr  301 0148
   Serial number: 35200E050C913000000B
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 454 801 702 18
   Component: FrontSensor_D  304 0149
   Serial number: 35500D17B8313000000H
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 GD    HW: 5Q0 953 549 F
   Component: Lenks. Modul  003 0140
   Revision: --------    Serial number: 14031820240464
   Coding: 1400
   ASAM Dataset: EV_SMLSKLOMQB 020002
   ROD: EV_SMLSKLOMQB_020_VW37.rod
   VCID: 7EA5FEE540748B2A7DF-802A
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5E0 920 751 E    HW: 5E0 920 751 E
   Component: KOMBI         303 0310
   Coding: 07A50A002180000801887F011001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009060
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 270BFB81FF6EEAE26E9-8072
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 L    HW: 3Q0 907 530 C
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007591467 Dataset Number: V03935276GC 0001
   Coding: 030100345F087300EB000248080F00010001070000000000000000000000
   GVL: 01543C0000000100C00C80000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 382928FD22D0751AF73-806C
   Generator:
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000C0090130318
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 J    HW: 5Q0 915 181 J
   Component: J367-BDMConti  H03 1050
   Serial number: 758860000018031412C8
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 57A 857 511     HW: 3G0 857 511 G
   Component: FLA           H10 0010
   Revision: AA001001
   Coding: 0101000001000000000000
   Shop #: WSC 73430 031 12345
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 6889B8BD32F0259AA73-803C
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 E    HW: 5Q4 959 593 B
   Component: TSG FS        011 0032
   Serial number: 0000307439774  Dataset Number: V03935252QV 0001
   Coding: 00110120D000040000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 47CB5B015F2E0AE28E9-8012
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000019996596
   Coding: 010200
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Dataset Number: V03935278BA 0001
   Coding: 01170000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B3DFD17B36D642021-8026
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 E    HW: 5Q4 959 592 B
   Component: TSG BFS       011 0032
   Serial number: 0000308940878  Dataset Number: V03935252QY 0001
   Coding: 00110120DE00040000001100
   Shop #: WSC 73430 790 12345
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 46D55605582413EA75F-8012
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000019927996
   Coding: 190200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
   Component: MU-S-ND-ER    H41 0471
   Serial number: SKZAZ2U0475323 Dataset Number: V03935278EJ 0001
   Coding: 03730201FF00000041111201008802002F0208C401200500CF
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 34311CCD3EB8917ADBB-8060
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: SKZ6ZHV0693627
   Data carrier:
   Subsystem 2 - Part No SW: 5L0 051 236 AD    HW: -----------
   Component: ECE1 2018  --- 0910
   Serial number: --------------------
Address 69: Trailer (J345)       Labels:| 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: Anheanger     H14 0137
   Serial number: 00006789,,+''. Dataset Number: 5E0124t____ 0004
   Coding: 0100000202000000
   ASAM Dataset: EV_TrailFunctGener2Hella 001005
   ROD: EV_TrailFunctGener2Hella_VW26.rod
   VCID: 392F2DF919DA6C1208D-806C
End----------(Elapsed Time: 01:27, VBatt start/end: 13.2V/13.2V)-----------
You forgot to update VCDS.
And to add the codinglog.csv and adplog.csv from C:\Ross-Tech\VCDS\Debug...
AdpLog.CSVCodingLog.CSV
Unfortunately I can not do an update on it this days!
Oh? Why not? Is it a cloned interface?
I don't know, it say on paper do not update.
Edited by lukik
Did it come with software on a CD?
If it did then as it's the English version of VCDS then 100% it's a clone.
Yes.
So in this case I can not do nothing ?
18 minutes ago, lukik said:
Yes.
You have purchased a clone of VCDS, which we do not wish to support.
Please contact the seller and tell them they have sold you a clone and ask for a refund, then visit the Ross-Tech website and purchase a genuine copy.
Unthil I solve with this clone, I can not do nothing regarding to high beam?
Not unless you can work it out yourself, as we won't support VCDS clones.
In my experience the beam assist feature is far from perfect.  It works pretty much flawlessly through the summer months, but in the winter I do seem to have issues with it.  I suspect, but never proved, the cold weather is causing condensation on the inside of the windscreen, and although I have a heated screen, it takes a while for the minimal amount of condensation in the sensor area (behind the driver's mirror) to also clear.  When the gremlins strike I frequently find the car stays on main beam despite something coming the other way, necessitating my manual intervention to dip the headlights.  Conversely, driving on a totally dark Cheshire road, the lights will be very slow to put main beam on when required.
The feature I find most annoying though is something in the auto beam function which has trouble identifying the rear of a car, specifically when I'm queued right up behind them.  There seems to be something with the high vis and reflective patterns on the back of traffic police Volvos which the system just doesn't like.  Lost count of the number of times I've suddenly gone to main beam right behind a very surprised traffic officer!
