O3 2013 reverse camera/not original
Hi,
Don't know about the coding hopefully some else will answer that.
When you take the head unit out of the car (the original radio) the radio will have a wiring diagram attached to showing the pins. You should be able to sort it out from that.
Hi
I'll probably find out, but will the adapter go there if it's for another radio?
if I take the wires out of it and connect it to the radio unit, will it work?
